I am overhauling the 1107320 starter on my 67 300hp car and the new lever (1951567) can install either way. There is a cutout in the lever stamping near the through pin hole and if turned 180* I think it places the lever throw differently.
Can someone post a picture or describe the correct orientation of the lever. The 1963 shop manual is vague here except to say if pinion clearance is more than .140 the lever pins are wore or incorrect assembly of the lever. I replaced the lever with a NOS part because the pins are wore and engaged the starter and the pinion clearance looks like a good .125 or so but with all new parts I would think it would be tighter so I am questioning the lever installation.
Thanks for the help, Tim
