Re: Joe Randolph's stroker article in the most recent Corvette Restorer
Fllight judging is based on what can be seen, not knowledge or rumors of what cannot be seen. I know of one case where a highly respected member and past NCRS officer built a cheater motor that may have been known to a few then current officers, but it received a Duntov Award and was the subject of a Corvette Restorer article after the award was earned that revealed all the internal engine details and included dyno test results.
Nevertheless, if one is building a cheater motor, it would be prudent to keep the internal details classified until you have finished whatever judging program you wish to participate in, assuming you do.
I was an engine system engineering advisor in the above case and designed a custom camshaft for the stroked 283. I recommended to the owner (who is also an experienced PV judge) that he only use about 3/4 throttle during the PV WOT test to 90 percent of the tach redline because any experienced PV judge would know that his engine made a lot more torque and power than the original configuration. He just laughed and said his objective during that test was to scare the hell out of the judge.
