69 SB restore - NCRS Discussion Boards
69 SB restore
  • Roger D.
    • June 3, 2014
    • 180
    69 SB restore
    I was wondering as I approach the time to put the body back on the chassis is the exhaust for a GM side pipe install require the spring choke mechanism on the passenger side exhaust pipe or is that only for under body exhaust.
    Thank You
    Roger
  • Leif A.
    • August 31, 1997
    • 3607
    Re: 69 SB restore
    Roger,
    If you're asking about the exhaust heat riser valve, then ALL SB '69 Corvettes had one factory installed.
    Leif
