Where can I get spark plug wire separators that (1) will accommodate 8-10mm wires, and (2) will slip onto the stock valve cover brackets?
As you know, one 4-wire and one 2-wire separator is needed for each side.
I've searched many of the usual places with no luck. I can find stock separators for smaller diameter cables, and aftermarket separators that don't have a slot to mount to the stock brackets.
I'm asking because I installed Taylor 8mm Spiro-Core braided cables. They're 8mm cables with a braided steel jacket so overall diameter is a bit over 9mm. BTW, they look "almost" stock (at least to the untrained eye) and seem to work great. No more cross-firing is heard and the engine runs more smoothly compared to my reproduction braided cables.
