I'm getting prepared to mate-up a 327 with a Tremec and drop it into a stock frame. With all the discussion of driveshaft angles that I've seen, I have a couple of questions, (just so I can understand what the original design intent was):
On original mid-years, in the side view, were the axis of the engine crank, driveshaft, and pinion all intended to nominally be aligned with each other on the same center in car position, or were the engine and pinion on the same angle, but not aligned on the same axis?
What was the design angle of the crank axis relative to the frame in the side view? (I measured my stock 63 car and the engine crank axis appears to be about 3 degrees to the frame rail)
