When rebuilding a rear caliper on a 67 do you install the hydraulic lip seal in the bore first then push in the piston or do you install it on the piston then put the piston in the bore with the seal installed. I just rebuilt one rear caliper for the first time and installed the hydraulic seal on the piston first then had to hit the piston with a socket to get the piston in the bore with the seal on the piston. Well the job is a bust. And I think I know the answer to my question but wanted to find out from someone who has actually done it.
Lawrence
Lawrence
