lost accessory side feed at fuse panel - NCRS Discussion Boards
  • Wally A.
    • May 31, 1979
    • 170
    my 62, lost its accessory side feed at the fuse panel, power feed top 2 fuses ok, rest are dead,
    accessory feed at ignition switch ok, whats next???
  • John F.
    • March 23, 2008
    • 2395
    Re: lost accessory side feed at fuse panel
    Disconnect the battery and unscrew the fuse panel from the firewall. My 62 had a broken/corroded wire on the back. You can do a search on this forum and see the pictures.
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11302
      Wally, the top 2 fuses are powered by the Main feed from the Ammeter output, so that's okay.
      The lower three are powered from the Pink feed which is sourced from the Ignition switch. The switch has 2 Pink feeds. One goes to the Fuel and Temp gauge, the smaller gauge Pink. The heavier gauge Pink is the one feeding the fuse panel.
      The back of the IGN switch has Brown for the Ignition system.The ACC terminals provide the Pink power. You likely either have a defective IGN switch or a Open circuit from the Pink to the Panel, or possible corrosion behind the panel causing the problem.
      A test light or meter behind the IGN switch will tell you if that's the problem. If it's powered there, then put the probe on the right side of the 3 panel fuses. If nothing there, it's either a broken Pink wire in the harnes, or a bad connection in the panel.
      If so, disconnect the battery and remove the 2 screws holding the panel, tilt the backside towards you for a view of the backside.
      pics for reference. The small and large gauge Pink wires/white terminals that connect to the IGN switch can be seen in pic#3
      Rich
      • Wally A.
        • May 31, 1979
        • 170
        rich, thanks for the reply, could of not explained any better. will check the system, i suspect the problem is
        the fuse panel itself.... thanks again for your time and input.... wally
