Bubba at it again - NCRS Discussion Boards
Bubba at it again
  • Gary J.
    • April 1, 1980
    • 1229
    Bubba at it again
    Doing a frame off on a '67 A/C car and found this today as I was removing the dash and heater box. Bubba used a dryer vent hose to fill in the gap between the heater box and the defroster duct.
  • Michael J.
    • January 27, 2009
    • 7073
    Re: Bubba at it again
    Think a judge would have seen it?
    • Gerard F.
      • June 30, 2004
      • 3803
      You gadda do what you have to do to make it run
      Bubba
      Jerry Fuccillo
      • Michael J.
        • January 27, 2009
        • 7073
        Bubba
        • Mike T.
          • January 1, 1992
          • 568
          The PO of my '61 had removed the heater since they were mostly involved with racing but left the same special connector hose attached to the defroster duct, but mine came with the 'optional' duct tape.
          Mike T. - Prescott AZ.
          • Loren L.
            • April 30, 1976
            • 4104
            Bubba never sleeps..........and it's not because he does warranty work......
            • Tim T.
              • December 9, 2009
              • 141
              But unfortunately, when he does sleep, he sleeps well
                • 3415
                Hi Gary,
                Very nice!
                I recently saw a photo on another forum that showed car with a piece of flex duct running from the engine compartment through the firewall to one of the kick panel vents.
                Would the smell alert Bubba to that fact that he was likely being asphyxiated?!?
                • Mark E.
                  • April 1, 1993
                  • 4498
                  For my first car, I used dryer vent hose to fab an under bumper cold air induction.
                  Is it a bubba if it's a cool modification like this, or only if it's a repair?
                  Mark Edmondson
                  Dallas, Texas
                  Texas Chapter
                  • Gerard F.
                    • June 30, 2004
                    • 3803
                    Yes Michael,
                    Here's the bubba fix for my hardtop latch which held up for my trip back from the Denver Convention from Beaver Utah through Vegas to Sonora, CA (about 800 miles):
                    But before that, out of Salina, Utah the temporary bubba latch fix on a desolate road was this with the luggage strap:
                    I drove about 60 miles with this luggage strap in my face holding the hard top down to the steering wheel, as I shimmied along on delaminated front tires. When I got to Beaver, Utah I got the piece of wire, as well as 4 new tires.
                    Here's my bubba luggage placement:
                    I little fancier but similar to my immigration to California from New York in 1969.
                    But the bubba car really looks good cruising in Utah:
                    As a result of my 2800 mile trip, I have 4 new tires, a new clutch, correctly fixed the hardtop latch, and figured out the secret to the failed 67 signal switch. Vinnie, look forward to a Restorer story, this trip was an adventure for my wife and I.
                    Jerry Fuccillo
                    • Philip A.
                      • February 26, 2008
                      • 329
                      One man's Bubba is another man's MacGyver!
                      • Michael J.
                        • January 27, 2009
                        • 7073
                        That was a great story Jerry, glad to see it will be available for all to see and hear in the Restorer.
                        • Joe R.
                          • May 31, 2006
                          • 1822
                          Well said Phillip!!!
                          • Richard M.
                            Super Moderator
                            • August 31, 1988
                            • 11302
                            '63 PG Neutral Safety Switch. When I found it, I realized it must've broken years prior and Bubba simply reconnected the Purple Solenoid wire connectors together to bypass it. Found out when the wire inside under the dash got caught on the teeth of the Park Brake release. Dead short when trying to start the engine.
                            • Ed S.
                              • August 6, 2014
                              • 1377
                              Originally posted by Gary Jaynes (3503)
                              [ATTACH=CONFIG]64907[/ATTACH][ATTACH=CONFIG]64907[/ATTACH]
                              I have to ask - I was hoping someone would provide the answer without me having to ask. So, when the fit between the defroster duct and the heater box is not tight - meaning there is a lot of space where are being forced through the heater box will escape and not go up the defroster duct as intended - what or how is the space sealed? I've looked through a number of parts catalogs and the AIM and I do not see a solution. On my '64 the fit between these two parts is not tight and snug, actually it is wide enough to be able to insert my small finger in between the parts. BTW - I am very confident that the heater parts in my car are original and the car was never hit. Thanks in advance to all that offer advice.
                              Ed
