C2 Headlight operation switch - NCRS Discussion Boards
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11302
    Re: C2 Headlight operation switch
    Originally posted by Ara Gechijian (48542)
    Rich, A side note. IF you find an NOS one it will likely have the longer tab for up/down operation. The originals had the shorter tab. An easy fix. Carefully remove the retaining clips holding the unit to the body, swap the longer tab for a shorter one (find a junk original switch with the correct tab) and replace the unit and the clips and you're good to go. Obviously this would be for judging purposes and unnecessary if you aren't going to have the car judged. The tabs just rest in a recess in the body. Easily done. ARA
    Good info Ara, thanks.
