spray can paint that looks like zinc-plated - NCRS Discussion Boards
  • Bob W.
    • December 1, 1977
    • 799
    Has anyone found spray can paint that looks close to that of a zinc-plated part?
    Thanks Bob
  • Michael G.
    • November 12, 2008
    • 2155
    Re: spray can paint that looks like zinc-plated
    Valspar makes several different metallic spray paints, one of which is very close to zinc hue. I re-painted a few old zinc fasteners as well as the original long bolts that hold on the spare tire cover on my 63 and they all passed judging easily.
    Don't know the actual Valspar name for it, but I purchased it at Lowes a couple of years ago. You may have to try a couple of flavors to get the right one...I don't think you can make a large surface look plated, but on the small stuff, it works fine.
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11302
      I'll tell you what NOT to waste your money on........
      Eastwood Clear Zinc Aerosol
      It's terrible. It looks NOTHING like the label on the can.
      • Bob W.
        • December 1, 1977
        • 799
        Guys thanks for the replies. Richard you are 100% right on the Eastwood paint.
        Thanks again Bob
        • Peter M.
          • May 30, 2013
          • 358
          Hi Bob,
          I used VHT high temp aluminum on some small parts about 10 years ago, I thought it gave a bright zinc appearance. I have also used cold galvanizing compound buffed with a rag after drying but was not really happy with the result, more of a dull look.
          Kind regards,
          Pete
          • Tom J.
            Infrequent User
            • February 1, 2000
            • 26
            Go to Michaels crafts and purchase a product called Rub and Buff.The color to use is called dull silver it costs about 4.00 Use a soft tooth brush and lightly spread the product over your bolts they will cover rather easily then buff off excess with a flannel rag. You will be amazed at what it looks like. Intake manifolds can be coated also as this product is not affected by gasoline.
            • Gary S.
              Super Moderator
              • February 1, 1984
              • 456
              Rub and Buff Silver Leaf....amazing stuff. My 67 350 HP original valve cover bolts.
              Avatar--My first ever vette, owned 3X since 1977, restored 1993-2024. Top Flight Award 9/14/24
              • Michael G.
                • November 12, 2008
                • 2155
                Looks good, Gary. I give it a shot too.
                • Bob W.
                  • December 1, 1977
                  • 799
                  Tom-Gary thanks looks great will try some.
                  Thanks again Bob
                  • Gary S.
                    Super Moderator
                    • February 1, 1984
                    • 456
                    Another picture that shows better...did the top of my idler arm. Great "cheater" coating...and easy touch up if needed.
                    • John D.
                      • December 1, 1979
                      • 5507
                      Today getting parts cadmium plated is increasingly difficult and very expensive.
                      Zinc plating is readily available and very cheap to have done. John
