A-6 compressor yellow TEST OK CHEVY stamp, when did they stop using it. - NCRS Discussion Boards
  • Domenic T.
    • January 29, 2010
    • 2452
    Not much known about date code position an back plates and now getting some questions about the yellow stamp. What year did the stop using the yellow stamp?
    DOM
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: A-6 compressor yellow TEST OK CHEVY stamp, when did they stop using it.
    Dom -- not getting much action here; guess no air cars. Does this question have to do with the update to the '65 TIM&JG? If so, this is a little early, as it's off a " ...133" compressor from an early '64 (Belair ? -- got it at a Pomona swap meet), rear head cast J183; but at least it's unrestored -- hey, even the spelling of "refrigerant" is correct . The stamped serial # is 85NC1885.
    If this is for the '65 manual update, are they gonna ask about the 6-hole clutch hub ? (ie. when did it go to 3 large rectangles)
    • Domenic T.
      • January 29, 2010
      • 2452
      Wayne,
      Actually I was asking about the yellow stamp because in the restoration of the C-3 compressors it is not known when they stopped using the stamp.
      I saw a documented 1970 without the stamp and a 5" pulley instead of a 5 3/4 pulley. I did C3 compressors and they all had the larger 5 3/4 pulleys. I started keeping records as to what is on the compressors and where the date code is on the back plate. There was another thread about the yellow stamp back in 2011 that had O response.
      BTW, nice find, does your compressor have 3 or 4 mounting holes (3/8x18) on the back plate? Also the serial # raises another question I have. When did they go from the serial # which is on yours to the mm/dd/y/shift in the foil code box?
      Dom
      • Domenic T.
        • January 29, 2010
        • 2452
        Wayne,
        Forgot to comment on your pulley. looks like a 5 3/4". Thought they were only on the Corvette, and the 5" on the passenger cars.
        Dom
        • Peter L.
          • May 31, 1983
          • 1930
          Dom - The AC compressor on our Sept 1966 build '67 equipped with C60 is MODEL NO. 5910645 with 072762 CODE NO. & has the yellow "OK FINAL TEST CHEV" stamp on it. Pete
          • Domenic T.
            • January 29, 2010
            • 2452
            Peter,
            Just got a PM about the 1970 and no yellow stamp. the C2's all had them and now to find out if the 1968 and 1969 had the yellow stamp.
            DOM
            • Gary J.
              • April 1, 1980
              • 1229
              Could someone not put a sticky out using a survey ?
              • Brian M.
                • February 1, 1997
                • 1837
                January built 67 with stamp.
                • Domenic T.
                  • January 29, 2010
                  • 2452
                  Brian,
                  Are you saying that January 67 was the last yellow stamp, or is that the build date of the compressor that got the last yellow stamp? I have seen lots of 67 compressors with the yellow stamps.
                  Dom
                  • Keith B.
                    • September 15, 2014
                    • 1575
                    Dads June built 67 has a March or April dated comperser with the yellow "OK" stamp
                    • Brian M.
                      • February 1, 1997
                      • 1837
                      Dom, I'm saying that my Jan built 67 has the OK stamp.
                      Originally posted by Domenic Tallarita (51287)
                      Brian,
                      Dom
