Is there supposed to be one with 7-digit part number attached to a side cover bolt. Nothing about it in the JG thay I found. Thanks
Metal tag on 66 Muncie
Re: Metal tag on 66 Muncie
It is my understanding the transmission tag was a factory installed item and the various numbers correlated to the transmission application. It is not a judged item, same as the trans VIN or date stamping are not judged by NCRS
Trans Tag.jpg- Top
Mike, found this on my 66 M21, original to car with L36. Only 5 digits.
IMG_0123.jpg- Top
Bruce - if you take that tag off probably going to find numbers under the bolt or what's left of them.
See this prior Forum post https://www.forums.ncrs.org/showthre...880853-3880855
The '66 L36 Muncie tag called out in the AIM is 3880855. 7 digits. The 5 digits you posted are the end numbers of that tag
- Top
