Upper "A" arm inner shaft grease - NCRS Discussion Boards
  • Jerry W.
    • January 27, 2009
    • 588
    Re: Upper "A" arm inner shaft grease
    The rules are easy to follow for me. Always read the following posts.
    John Hinckley....Joe Lucia...Tom Parsons....and Rich Mozzeta....Thanks Guys.
    • Eric E.
      • November 1, 1998
      • 254
      For reference, here's some info on the dimple and with Tom's guidance many years ago he taught me with some clever ways to use some old parts for tools.....
      Used this process a few months ago to change both upper shafts when rebuilding the front suspension and it worked like a champ.
      • Donald H.
        • November 2, 2009
        • 2580
        When I did my 60 I absolutely used every piece of information from Tom that I could get. I used his instruction on the steering box, rear (putting a newer style Eaton posi unit into an original C1 posi carrier) and rebuilding the front suspension.
        Don
        Don Harris
        • Rod K.
          • April 1, 1990
          • 441
          I agree and add Mike McCagh...Gary Chestnut....and Duke Williams! Couldn't do it without all of you.
          • Keith R.
            • August 31, 2001
            • 660
            Originally posted by Eric Eade (31337)
            The spindles and spindle supports should be cast, but, cast and bead blasted do not look the same. Natural cast is a darker grey than blast.
            I went bead blasted and non gloss clear but I am not as concerned as some might be.
            A trick I learned was to use gun-blue to darken the component following bead blasting. I've used both liquid and paste. You don't have to leave it on the piece too long then wash it off and dry it. Even out the finish with some 00 steel wool and then clear coat with Eastwood's satin clear.
            Keith MacRae
            NCRS #36692
            New Mexico Chapter
            1960 290HP FI
            2013 427 Convertible
            Shade tree mechanic and
            B-52 pilot extraordinaire
            • Bob W.
              • December 1, 1977
              • 799
              Tom SORRY to hear you feel that way . I have to agree with Jerry and Rod. When I see certain names next to a post I read them and your name is one for them.DONT STOP POSTING !!!!!!!
              Thanks Bob
              • David R.
                • March 2, 2017
                • 31
                Tom, nicely done write-up on rebuilding front suspension. Tried sending you a PM, since this post is two years old. Had several questions for my 62.
                David
                • Tom P.
                  • April 1, 1980
                  • 1814
                  David
                  David,
                  PM sent, But sorry, I forgot to include my phone number. I'll go back to the PM and include it.
                  • Francis F.
                    • April 1, 1978
                    • 420
                    #24
                    Tom, you are mistaken ,when you post I am all ears and copy machine.your posting very helpful,and I along with other members are retaining your articles.
                    Francis
