In preparation to get my 1972 454 engine fired up (after 22 years of storage), I'm searching for a high quality (preferably USA made) oil pump primer tool (with the oil galley collar). I see that there are many oil pump primer tools on the market and prices are all over the board. Any suggestions?
Jim
Jim
), turn the crank 90 degrees in its normal running direction using a breaker bar on the harmonic's bolt. Let the primer run for a few more minutes while watching to make sure all rockers continue squirting and the gauge shows pressure. Repeat for two revolutions of the crank (one rev of the cam). Turning the engine by hand (and not with the starter) gives you a feel for how easy the engine is rotating. You may use this opportunity to measure the torque required to do this and compare it to spec.
