Vacuum Source - 1958 Dual Quad - NCRS Discussion Boards
  • Thomas H.
    • August 31, 2005
    • 1053
    In the process of tuning my freshly rebuilt dual quad 283. Went to connect my vacuum gauge.............
    No external vacuum source anywhere?
    Ideas??
    Tom
    2007 Z06, Lemans Blue
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11302
    Re: Vacuum Source - 1958 Dual Quad
    Tom, On the rear of the Primary carb is a Pipe Plug. Remove that and use a adapter to connect to the gauge hose and when done just replace the plug. That port is full time manifold vacuum.
    Rich
    • Thomas H.
      • August 31, 2005
      • 1053
      Rich
      Hi Rich,
      Thought that would be the case, but didn't see one last night when I was poking around for a source. I know the pipe plug you refer to as I had left it out of my 60 when I rebuilt that carb - didn't run very well, but it also didn't take very long to find the source of the problem either!
      Sounds like the "correct" carbs I bought may not be so correct............. Great.........
      I'll take a look again tonight.
      Tom
      • Frank D.
        • December 27, 2007
        • 2703
        If you find you DO have a vacuum fitting in either carb then this Paragon piece is the way to go: https://www.paragoncorvette.com/p-35...m-fitting.aspx
        It is in two pieces so you can install/remove it with the carb on the car...
        If your car had the dual point distributor with no vacuum advance the there may not be a vacuum 'take off' on the carbs....
        Bob Kunz drilled one into the base of my dual quad setup for me to use...
        • Thomas H.
          • August 31, 2005
          • 1053
          Nope, no plug on either carb. Maybe shouldn't have one? I don't want to put one in if there shouldn't be one.........
          • Thomas H.
            • August 31, 2005
            • 1053
            Neat idea........
            • David Z.
              • April 1, 2002
              • 181
              Tom
              Here is the fitting that Frank referred to above. I've had this in our '60 since we swapped the vac advance distributor for the dual pt that was in it when we got it.
              Dave Z
              Dave Zuberer
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11302
                So I'm unsure now about the 1958 WCFB's. I thought they all had the rear fitting on the base. If yours are not supposed to have the fitting, there is yet another solution.....
                Install one of these hollow studs in the manifold to replace one of the carburetor mount studs, typically at the rear of the Primary carb. When you're done with it just replace the original stud and back to normal.
                Purchase 1957-1961/1969-1970 Corvette AC-Delco Spark Plug (R43S) at Zip, complete source for factory & performance spark plugs, wires & mounting clips.
                • Frank D.
                  • December 27, 2007
                  • 2703
                  Right where I was going Rich - CC has them too...
                  • Richard M.
                    Super Moderator
                    • August 31, 1988
                    • 11302
                    Yes it's a little bit of a pain but I think it'll be the solution.
                    Tom, If you get one just make sure the hole in the intake you use is not a blind hole. I know I have photos somewhere of a 2x4 intake backside but i cannot recall if they're blind or open or a combo of both.
                    I'd also hacksaw-cut a screwdriver slot on the top of the hollow stud to make it easier to get in-and-out whenever you want to connect your gauge to it in the future.
                    I did a base engine '59 a few years ago and it previously had a vacuum advance distributor on it. The (NTFP) configuration it had used that hollow stud. Worked nice.
                    • Frank D.
                      • December 27, 2007
                      • 2703
                      I added RPO-242 to my '61 (California PCV option) so my carb legitimately had a vacuum fitting in the base...
                      You can run a wire down the carb stud hole and measure to see if it makes it into the intake runners; it should be pretty obvious.
                      Just don't forget to cap off or remove that hollow stud when you're done tuning...or you'll have a killer vacuum leak...
                      If you have the Winter's "figure-8" manifold there is also a theory that these two bolt holes (see red arrows in pic) lead to a vacuum source so you could
                      possibly rig something up there too. I've never confirmed it but have heard it quite often!
                      • Thomas H.
                        • August 31, 2005
                        • 1053
                        Frank,
                        I do have the Winters manifold - those holes on my intake are flat bottomed.
                        Tom
                        • Thomas H.
                          • August 31, 2005
                          • 1053
                          [ATTACH=CONFIG]66139[/ATTACH]
                          Rich,
                          That thought crossed my mind. My 60 has this setup for the vac adv on the distributor. (BTW, the set up on the 60 is stock, so that hollow stud was how it came from the factory).
                          Tonight I'll check the carb stud holes and see if any can be used as a port.
                          Had the car running last night on the engine analyzer looking for the cause of a misfire above 2k rpm - looking at the spark waveforms it appears that my new reproduction coil is a bit on the weak side - go figure, another questionable reproduction part. Condenser (new also) tests a bit on the leaky side. Could be a combo of both. I have a new NAPA coil I'll put in tonight along with a new condenser to see if it improves anything.
                          Tom
                          • Thomas H.
                            • August 31, 2005
                            • 1053
                            I
                            Well what do you know.......... The rear most threaded boss is flat bottomed, but the forward one isn't!. Open right into the #7 intake runner.
                            Guess who was running the engine with it not plugged and wondering why there seemed to be a misfire......... Duh!
                            I'm going to plug it for now and continue on my tuning. Still have a coil problem that I hope to resolve tonight. Maybe I'll take my first drive around the block tomorrow!
                            Tom
                            • Frank D.
                              • December 27, 2007
                              • 2703
                              Yup - I've had a couple of C1 pals that discovered those two weird bolts were the cause of some vacuum problems....several theories about what they were for. The NAPA IC-12 coil works great on these cars and reasonably priced...
