Did Aluminum radiators have a petcock installed at St. Louis.? If so can someone describe it or post a photo.? If not, can someone describe or post a photo of what the plug looked like. The TIM&G does not address this. I believe the C-3's had a plug but not sure about the mid years.
1965 Aluminum Radiator Judging Question
Re: 1965 Aluminum Radiator Judging Question
Dave, C2 aluminum radiators had an all aluminum petcock, call Whittek for replacements, or any Vendor. (Brass rad. would be brass etc.)1964 Red FI Coupe, DUNTOV '09
Drove the 64 over 5000 miles to three Regionals and the San Jose National, one dust storm and 40 lbs of bugs!- Top
Dave, my small block aluminum radiator has a hex-head aluminum plug. The big blocks has a steel or brass hex-head drain plug, not a petcock.- Top
Dave,
Here's a photo of the petcock on the '65 fuelie coupe over here. Appears to be all aluminum.
This went to both the 2010 Regional and National so I'll check the Judging Sheets for notations later when I can.
I have the 2nd and 5th Edition Judging Guides here. I'm certainly not a '65 expert, but just to note.....
the 2nd edition states on Pg 120: "An aluminum hex-head plug is used in the drain hole"
The above sentence was omitted and is not noted in the 5th Edition JG on Pg 138. There is
reference to neither a plug nor a petcock in the 5th Edition JG.
I see why confusion exists.
Rich- Top
Dave,
[ATTACH=CONFIG]66433[/ATTACH]
Rich
Rich- this car received no deduct for a brass drain cock when judged in Kissimmee in 2014.- Top
Hmmm, The above pictured '65 Coupe built January 23rd received no deducts at the Kissimmee Regional 2010 nor the Charlotte National 2010 with the petcock.
Your car was built February 27.
Could it be one of those "Early vs Late" production things within all of 1965 production?
Just for sake of discussion, I can't recall if the above petcock, if in fact it was TFP because I don't remember if the ears of the thumbscrew are supposed to point down or up. I think down.
Rich
ps I just realized something after getting the dates from the C2 Registry BD calculator.... The above coupe was built on the past owner's birthday, and in 2010 he got a Top Flight on January 23rd, his birthday, and your car was built on, albeit years later, my Mother's birthday, February 27th.
(enter Twilight Zone music now at this time......)
- Top
Joe, the question was for C2's. I am not sure if 1965 and 1966 are the same. I looked in the latest edition of the 1966 judging manual. On page 160-161 states that both small block and big block have hex-head plugs not petcocks. Is this a mistake in the latest edition for 1966?- Top
Guys,
It doesn't matter whether it is a 63 or a 67. Aluminum radiators had aluminum petcocks as shown in the above pic. Later brass/copper radiators had plugs I am told. Maybe that's where the confusion starts. Even the earlier 60-62's had aluminum petcocks on aluminum radiators
supplied from GM with an aluminum extension. Will follow with pics as that is where I got my aluminum petcocks.DSCN4364.jpg
JR
PS. Even all aluminum radiators supplied from GM parts had the aluminum petcock.- Top
Oooooh, Ahhhh. Nice pieces Joe !!
edit.....
Thanks Harry. BTW, here's the link......ooops, price went up 50% since your post.
Model: 32-602 Exact reproduction of the aluminum drain valve used on 1963-67 Corvettes California Proposition 65 Statement
ears downI had a 50-50 chance and i got it right with only one coffee earlier.
- Top
joe et al: last month i removed a NORS 65 396 radiator, dated 1982, from its original shipping container. it had an aluminum hex plug in it. i removed the hex plug and installed an aluminum petcock. the radiator is currently in the 396 coupe i just finished restoring. i left the radiator and a snap-on etching tool alone in the shop on dark and dreary nite, and lo and behold, when i entered the shop the next morning, a 1965 date was present on the top of the radiator. Saint Michael- Top
