I'm a newcomer here and I'd appreciate some expert help.
I am trying to fix the windshield wipers on my 71 small block coupe (w/ air).
Problem:
When I switch the wiper switch to low or high the wiper door raises, the relay clicks, but the wipers don't start moving. I know the whole system used to work because on Oct 17th the car went through flight judging and all of the functions worked then.
What I know:
The wiper motor is good. I know this because I sent it out to be rebuilt and it was returned to me as functioning by Steve Hackel. I re-installed the motor and had it running, but had to swap out a sticky reproduction wiper switch with another reproduction switch and since then it won't work.
I have tested the new wiper switch following the instructions in the wilcox video, the new switch shows continuity in all of the same configurations as the video. I have also tested that there is continuity between the wiper switch housing and the metal air ducts inside of the dash.
I have also done my best to confirm that with the car running and the wiper switch in the off position that there is 12v of resistance on the yellow middle wire in the three prong connector. My ground (2 black wires) are also attached securely to the via a connector and bracket and screw to the wiper motor housing.
I have also turned the knob under the steering column to both positions to make sure that the power isn't cut. I am 90% sure that the knob needs to be turned counterclockwise to allow power through.
I personally think the issue is somewhere with the grounding, but I am acting on instinct alone, if someone could tell me how to eliminate grounding as a source of the error I would appreciate it. I am also open to any other ideas or opinions.
Problem:
What I know:
