Just wondering where to put 12 volts to the wipers to see if they even work, the motor is still on the fire wall, the wiper door is open, there is juice going through the switch that the door trips, did take the switch out and I have juice at the plug on the very left and the right wires with the switch on low, but only on the right hand side on high that is the one with the 2 light blue wires. I hope there is a wire behind the distributor where wiper motor plugs are that I can put 12 volts to, to see if the motor works. thanks.
