Hoping I didn't do something wrong while jacking the rear of my convertible up, and putting it on jackstands to do some work underneath the rear of the car. I've done this in the past numerous times since I've had the car, and did not notice any difference in the opening and closing of either door. However, yesterday when I let the car down and tried to open the driver's side door I had a hard time. It felt like it was stuck, and I had to keep trying a couple of times before finally getting it shut. I checked the door hinges by lifting gently and there was very little to no play. The door spring works as it should, although it was replaced at one time by a previous owner. Also, when I was inside the car trying to get out it did the same thing, it felt like it was stuck.
Any help or suggestions will be greatly appreciated.
thanks
thanks
Started to panic! When I let the right side down (really slow) first I heard a "creaking" sound, but I've heard those before. Patrick what do you mean by removing any twist on the car? Do you mean just letting it down like I did, then opening and closing the doors right afterwards?
