C2 Headlight telltale light - NCRS Discussion Boards
  • Jim B.
    • June 29, 2015
    • 53
    My '65 coupe headlight hi/low telltale light glows very dimly whenever the lights are on (hi or low) and glows brightly when the hi beams are selected. I have removed the dimmer switch from the circuit to try and isolate the problem further and when powered up, with the lights on the telltale still glows very dimly. Is it possible that I am seeming some bleed over of light from one of the adjacent dash lamps or should I suspect something more may be going on here?
    Thanks in advance
    Jim
  • Stephen L.
    • May 31, 1984
    • 3148
    Re: C2 Headlight telltale light
    Try turning off the dash lights by completely dimming them on the headlight switch. If the "problem" goes away then you have some bleed
    • Jim B.
      • June 29, 2015
      • 53
      Hi Stephen
      Thanks for the good tip. There must be bleed over from the adjacent dash lights because following your suggestion and dimming the dash lights fully down extinguishes the faint telltale light as well. When I take on restoring the dash cluster this winter, I will have a look in that area.
      Jim
