Part number 7043684 and 7043677 time frame and application? - NCRS Discussion Boards
  • Russ S.
    • April 30, 1982
    • 2161
    Can someone tell me what was the first usage date and application of these two part numbers? 9043677 and 7043677 They are rochester carb idle screw limiters. Thanks
    Re: Part number 7043684 and 7043677 time frame and application?
    Russ------
    GM #7043677 and 7043684 were first used for 1971 and were discontinued without supercession in 1981. Neither superseded or was superseded by the other. Also, neither was ever cataloged for a Corvette application. However, they did have wide application over many GM carlines, including Chevrolet.
    • Russ S.
      • April 30, 1982
      • 2161
      Thank you Joe.
      Russ------
      • Russ S.
        • April 30, 1982
        • 2161
        Alan, I also have #7042801 which as you picture are said to be for 71-73 (or maybe to 75). I have them on my 73 however a friend tried to put them on his 73 and they wouldn't fit. Is it possable that his 73 has replacement needles with a larger head?
        Hi Russ,
        I have something similar(?) with a different part # indicated.
