The weather here in SW PA. has really been unseasonably warm for this time of year, so I decided to take advantage of it. I took my air cleaner off to make it easier to switch out the Delco Remy 1115202 coil that came with the car to an OEM Delco Remy 1115270 BR that belongs on the car. While doing so I noticed a stain on the intake in front of the carb. I appears to be coming from the small round screen (plug)
in front of the carb. I'm not a mechanic, so I'm wondering if this can easily be fixed by me, or should I have my mechanic fix it, if in fact it can be fixed? Any help as always would be greatly appreciated. I've included photos below.
Thank you
in front of the carb. I'm not a mechanic, so I'm wondering if this can easily be fixed by me, or should I have my mechanic fix it, if in fact it can be fixed? Any help as always would be greatly appreciated. I've included photos below. Thank you
So, I am going to attempt this and I will be carefully removing the carb (and documenting everything with pictures so I can remember where everything goes). I'll be able to bring it into the house where it is much warmer for the epoxy to cure. I was just wondering if there is any one type of fuel resistant epoxy that is better than the other. Hopefully, one of you guys who have done this will chime in. I don't have much luck with JB Weld, its never worked very well on anything I've tried. But I know that many stand by it and use it all the time. Wonder if anyone has any pictures of one that has been repaired with epoxy, so I could see where it was applied.....
