'67 Convertible. Body drop today. A few questions...
1- Radiator support going in. There are shims on each side. Since support was installed with it's shims in place before body drop, should they show evidence of blackout on their edges? Also, were the four 5/16" diameter side bolts bolts holding the support in place before or after the undercoating and blackout process?
2- I'm planning to install the shifter and adjusted shift linkage before body drop, yes? Was this normal St Louis practice? I will remove the console shift boot and retainer so the tunnel opening is completely open. I have done 3 midyear body drops before, 2 on 2 '65's, and a '66, but for the life of me I can't recall the shifter status when we did them.
