67' clutch cross shaft - NCRS Discussion Boards
  • Dave K.
    • January 24, 2013
    • 278
    The JG states that factory installed cross shafts have a reddish/orange plastic plug on the underside of the shaft. Is this where the Zerk fitting is located?? My particular cross shaft has a zerk fitting; i did not see a reddish plastic plug. Also is the entire hollow steel tube filled with grease; or what is the proper way to assemble?? FYI: My cross shaft is completely disassembled and cleaned inside and out; i'm just getting ready to put it back on to the inboard and outboard stud.
    Thx Dave
    Re: 67' clutch cross shaft
    Thx Dave
    Dave-------
    The zerk fitting is where the plug was originally installed. Years ago, someone replaced the plug with the zerk fitting for the purpose of easily greasing the ball studs on the ends. This was very common. Greasing the ball studs by filling the cross shaft with grease was and remains the easiest method. It's far from the best method, though. The best method is to remove the cross shaft and grease the ball studs directly.
    • Donald A.
      • March 1, 1987
      • 243
      It is my understanding that the 67 as delivered from the factory had the red plastic plug in the cross shaft hole. At the time of the first servicing or whenever someone wanted to grease the ball studs, the plug would be pulled out and a zerk fitted to the hole. For judging the red plug should be there, not the zerk. And as noted, you don't need to use the zerk and fill the entire tube, just makes a mess for years to come as the grease heats up and leaks out. Just disassemble and grease the ball studs lightly directly as Joe Lucia pointed out.
      • Peter L.
        • May 31, 1983
        • 1930
        Dave - There was a FORUM discussion "MIDYEAR CHUTCH CROSS SHAFT PLUG" in 2000 you might find interesting. Pete
