I am trying to salvage a couple of hanger brackets. While one has a couple of stripped holes I have two that just have broken bolts. Before I put the effort in removing the bolts, are the eye pins pressed into the large diameter opening in the bracket or are these just the typical rust fit? I had to cut the pins out to remove the leaf springs. Thanks as always!
C1 Rear Shock Hanger Bracket
