Have a 63-360HP and the right exhaust manifold has a hole in the top for the heat tube but no tube or hole in the bottom for the tube. Top hole is not as large as I am used to seeing. Is this possible? Thanks in advance
1963 FI right exhaust manifold
Re: 1963 FI right exhaust manifold
Jerry, Sounds like someone didn't have a clue what he was doing on his carburetor car. As you know the choke works on hot air and not exhaust gas/soot.
Also sounds like someone took an original 360 HP manifold and drilled a hole in the top. Get it welded up and textured. John- Top
Previous owner thought he could turbocharge things by feeding a little exhaust gas back into the carb...
- Top
