1100884 Alternator - NCRS Discussion Boards
1100884 Alternator
  • Ralph S.
    • February 1, 1985
    • 935
    1100884 Alternator
    DSC00729.jpgCan this be fixed and what would it cost.
    • 6940
    Re: 1100884 Alternator
    Ralph, Try John Pirkle he is in the driveline, that is a very expensive alternator.
      Originally posted by Ralph Spears (8296)
      [ATTACH=CONFIG]67780[/ATTACH]Can this be fixed and what would it cost.
      Ralph------
      It would be easier and "cleaner" to fix if you had the broken-off piece. However, either way it can be fixed. As Edward mentioned, John Pirkle may be able to repair it. I'm sure that Jerry Macneish could do it, too. Also, if you can find a really good aluminum welder in your area, they could probably do it.
      The advantage of using John Pirkle or Jerry MacNeish is that they understand that you want a functional AND cosmetic repair; a local aluminum welder probably won't.
      • Rick A.
        • July 31, 2002
        • 2147
        Check also with Ken Bruno Motorsports as an alternative
        Rick Aleshire
        2016 Ebony C7R Z06 "ROSA"
