Engine case ID - NCRS Discussion Boards
Engine case ID
  • Thad L.
    • April 30, 1999
    • 168
    Engine case ID
    What was it?
    cast #3970014
    cast appears to be 1973
    pad numbers. 13Y138666
    T0120CKL
    Thanks. Thad
  • Rick A.
    • July 31, 2002
    • 2147
    Re: Engine case ID
    Here's the applications that I found:
    3970014 350 69-77 Pass, Chevelle,Camaro, Nova,Monte Carlo 2 or 4 bolt main
    3970014 350 69-79 Truck 2 or 4 bolt main
    3970014 350 72 Corvette late '72,200 HP,255 HP 4 bolt main
    Rick Aleshire
    2016 Ebony C7R Z06 "ROSA"
    • David L.
      • July 31, 1980
      • 3310
      Re: Engine case ID
      According to my 1973-75 Chevrolet Parts Catalog (Sept. 1973):
      "CKL" = 1973 Chevrolet Pass. 350 (L65) w/T.H. and 1973 Chevelle 350 w/T.H.
      "13Y" = Chevrolet, 1973, and GMAD - Wilmington assembly plant
      "T" = Tonawanda engine plant
      I have a 3970014 block that I bought in Carlisle, PA, which was from a 1970 Camaro SS350 (L48) with a casting date "E 16 70", stamped "T0518CRE" on front pad and "10N5?1710" near oil filter ("N" = Norwood where east coast Camaro models were made).
      Dave
      • William C.
        • May 31, 1975
        • 6037
        Re: Engine case ID
        CKZ was used in '73 MY, Base 4 speed setup. Does the VIN sequence match the car, or is it just an orphan engine?
        Bill Clupper #618
        • David L.
          • July 31, 1980
          • 3310
          Re: Engine case ID
          "CKZ" = 73-74 Corvette (L48) w/M.T.
          I believe that most all Corvette 283, 327, and 350 engine blocks were made if Flint except for a few exceptions (maybe a few in 1964 or 1965).
          "CKL" is not a Corvette engine stamping.
          Dave
            Re: Engine case ID
            Originally posted by Thad Lejeune (32187)
            What was it?
            cast #3970014
            T0120CKL
            Thanks. Thad
            Thad------
            All GM #3970014 blocks were cast at the Tonawanda foundry. For some reason, this was a Tonawanda-only casting number. That's fairly unusual as most small block casting numbers were cast at both Saginaw and Tonawanda.
              • 15573
              Re: Engine case ID
              Some of those 3970014 Tonawanda cast, but Flint machined, cylinder cases found their way into Corvettes in the 1969 to 1973 model years. Obviously (CKL) not this one, however. There was a Restorer story on the subject and the existence of these 0014 cylinder cases is mentioned in both the 1968-69 and 1970-72 TIM&JGs.
              • Thad L.
                • April 30, 1999
                • 168
                Re: Engine case ID
                Thanks for the info!!!
                Thad
