Well it finally happened. The front bumper has cracked and will need replacement. It cracked just off center of the middle which mimics a pic that was posted on an earlier thread location wise almost EXACTLY. Has anyone recently installed the replacement urethane bumper lately. It is slightly less expensive then the GM OEM replacement ($512 vs $699). Which should I choose?
My car is original and has the original hardware and substructure present which I would like to keep. Yes I know I will probably be replacing again in 20 years
Second question; Is it best to fully install the bumper and then paint when using the urethane.
Tis
Tis
