Planning on getting started on this the next few days... Looking forward to it but some I've talked to have said that unless the body is off it's pretty tough to get the job done what with the tight quarters in the wheelwells.... What say you?
Second question: It's a small block so will the lower A-Arm drop down low enough to get the spring out or will I need to compress it before I pull it out?
Thanks in advance
Thanks in advance
