At some point in the past a previous owner(s) of my '69 L36 replaced the white coil resistance wire from the coil to the fuse block with a non-resistant wire, then added a C2 style external ceramic resistor. I want to get the wiring back to something that resembles the original configuration. To do this, I need to replace the white resistance wire.
What type of wire should I use for this and where can I get it? Or is my only option to construct a wire with a small inline resistor?
Thanx
-Floyd-
Thanx
-Floyd-
