70 original exhaust tip Clamp
Re: 70 original exhaust tip Clamp
Pretty sure you are golden with a K. Might be OK with nothing also, depending on the judge. At most with nothing on it a dot would be all they are worth. ALL the exhaust clamps and brackets are lumped together, so there is a lot to fit into a small point allocation.Terry- Top
If you install it as-is on an original appearing car, I'd bet the judges forget to look for the K if it "looks like it fits."
If you're restoring it for use on a restored car, check for the K, though I'd use it anyway in a location where you can't get at the K.Vice-Chairman (West), Michigan Chapter NCRS
