radiator hose marking question - NCRS Discussion Boards
  • Mike E.
    • February 28, 1975
    • 5134
    I certainly understand the 7-digit part stamping. I also understand the reason for the stripe down the hose--so the worker could properly align it. But what do the other two-letter stampings mean? This particular hose is a factory original on a 30k-mile 67 SB. In other words, what do the "AU" and the "TQ" mean? I've seen the "AU" on other hoses for other years and applications, by the way. Are those simply internal coding of some sort? And if so, do we have any idea what they mean?
    Thanks in advance.
    radiator hose--lower (2).jpgradiator hose--lower (3).jpgradiator hose--lower (4).jpg
    • 15573
    Re: radiator hose marking question
    Thanks in advance.
    [ATTACH=CONFIG]68621[/ATTACH][ATTACH=CONFIG]68622[/ATTACH][ATTACH=CONFIG]68623[/ATTACH]
    I am pretty surew AU is a manufacturer code for GoodYear. I am not sure about TQ, bit I expect it is also a manufacturers ID code.
    • Robert G.
      • May 31, 1990
      • 429
      How about a broadcast code? I have a 1969 chev broadcast sheet and it notes upper and lower radiator hoses as UC and UD.
      • Gary C.
        Administrator
        • October 1, 1982
        • 17549
        Mike,
        AFAIK the Hose manufacturer identification codes were colored yarn inserted in the rubber per the Rubber Manufacturer's Association.
        The blue print for 1957 radiator hose does not specify a manufacturer's logo or marking as required.
        Gary
        NCRS Texas Chapter
        https://www.ncrstexas.org/
        • Mike E.
          • February 28, 1975
          • 5134
          Robert,
          Can you tell me/us more about the broadcast sheet and what all it consists of? I'd appreciate that.
          Mike
          • Robert G.
            • May 31, 1990
            • 429
            It's for a full-sized chevrolet. Are you sure you are interested? It has the production date, vin, key codes, ident, body, color, etc. In total there are 142 different numbered items.
            • Mike E.
              • February 28, 1975
              • 5134
              I can't speak for others, but I'd like to see it. If for no other reason, to compare it to the one I have for the 71 Chevelle I bought new.
              • Robert G.
                • May 31, 1990
                • 429
                DSC00943a.jpgDSC00945a.jpgHere are a couple of photos. I had to split it in two to get it readable and of decent size.
                • Ara G.
                  • January 31, 2008
                  • 1108
                  Mike, you say SB 67, but don't indicate if it's a base motor 300 or L79 350. The base motor rad hose was 154 and the L79 ended in 156. Your hose doesn't look like it ends with 154 or 156. Just curious. I have a wonderful picture at home on my ipad of a Bowtie 67 L79 and from what I remember off the top of my head the lettering is configured differently than the hose you photographed. I will look tonight and get back with all of you. I mention the part numbers to you as you should make sure first of all if it's the correct hose to begin with for the car. Just my two cents...Thanks. ARA
                  • Mike E.
                    • February 28, 1975
                    • 5134
                    Ara,
                    It looks a lot like 3887155 to me, which is the correct lower hose according to the JG. And it makes no difference whether base motor or L79, that's why I didn't differentiate. I generally do my homework before I post and ask a question.
                    • Mark E.
                      • April 1, 1993
                      • 4498
                      ...what do the "AU" and the "TQ" mean? I've seen the "AU" on other hoses for other years and applications, by the way. Are those simply internal coding of some sort? And if so, do we have any idea what they mean?
                      Thanks in advance.
                      I'm pretty sure the AU means golden fairy dust was applied to the inside of the hose for off road use.
                      Mark Edmondson
                      Dallas, Texas
                      Texas Chapter
                      • Michael M.
                        • February 7, 2011
                        • 186
                        I believe Robert is correct. From my days working at the Fremont plant, I can tell you that just about everything was identified with a two-letter code for the assembler, and I’m sure St. Louis was the same. The broadcast sheet called out the codes of components based on the car’s options – the intent was to make assembly “fool-proof.” That’s why you see two-letter stamps/labels for everything from engines to alternators.
                        Not Corvette, but here is a pic of the earliest broadcast (this one is GMAD) I could find - '72 Monte Carlo from Van Nuys. You can see all the two-letter codes and some numeric - usually the last three of the part number.
                        • Mike E.
                          • February 28, 1975
                          • 5134
                          Any idea when those codes began? In other words, what would the assembly line worker have had in 1967, for example, to reference the two-letter code?
                          • Michael M.
                            • February 7, 2011
                            • 186
                            I can't speak definitively for St. Louis (maybe JohnZ can chime in), but Fremont was using a broadcast sheet in '65 when I started working there. We were a BOP plant (Buick Olds Pontiac Assembly Division) at the time and went under GMAD (General Motors Assembly Division) control sometime later in the '60's. There was some variation across the assembly divisions but all used some form of broadcast/build sheet/manifest/run sheet to define build components since the early '60's or before. So I'm sure St. Lewis was using some form of broadcast sheet in '67.
                            A favorite saying on the engine dress line used to be "if all else fails, read the manifest" in the context of wrong parts being assembled on a specific engine.
                            • Richard M.
                              Super Moderator
                              • August 31, 1988
                              • 11302
                              Interesting thread Mike, et al.....Some great info all are sharing.
                              Some more examples of the 2 letter codes. These from a '63 A/C Power-Everything convertible I found a few years ago, but wasn't able to acquire.
                              Lower AU
                              Upper AY
                              80-picture_php_pictureid_135653_d4c96816fb1b3269c3bd07b0537f589eee6f29e7.jpg 80-picture_php_pictureid_135655_e7001bd0e45446f17e239322a598847df9aec6f6.jpg
                              The find.....
                              80-picture_php_pictureid_135683_bc2d389321a362dce39113285d84d9f890cd9cef.jpg 80-picture_php_pictureid_135684_f6d56a58236fbff5085ca02400218d112c9b6ca1.jpg 80-picture_php_pictureid_135664_ee03dc54db522f8931759aa2c18fc25fc0a18ee6.jpg 80-picture_php_pictureid_135659_809e123de31c5cb6d8a66fa92e3861ac8b1253a1.jpg
                              I also have a (original-I think)lower hose from a 67k mile '63 coupe we owned. I'll post a few pics of after I find it in my pile of junk. IIRC it has a AU code on it too.
