I was unable to start my 1960. No fuel in the filter bowl and gas gauge reads full. Cleaned the filter bowel, checked the lines for cracks, replaced the filter and still with constant cranking was unable to get fuel into the line or the carbs. Was able to put gas in carb and start up - but of course quickly died out as no gas from tank to carbs. Figured it was fuel pump and was going to replace myself - but too hard to get under the car so took it to a local mechanic that I have used before - (he is knowledgable and respects a classic car) - anyway he pressurized the fuel tank and car started - we put an additional 2 gallons of fuel in the tank and car started right up and ran just fine. So obviously tank is not full - probably closer to empty. So the question is the fuel gauge which continues to read full. Does anyone know what the default reading is if the gauge is bad (full, half-full or empty) or if the sending unit in the tank is shot? Or is it possible that the line in the tank has moved and is only drawing off of the top of the fuel level?
Plan to start it up again tomorrow morning - and if it starts I will take it and fill with gas - if it takes 10 or 15 gal then it would seem that the gauge is misreading for some reason. Then question is to replace gauge, sending unit or just monitor milage and fill frequently with gas. Any thoughts would be appreciated as always.
Ahh - the fun of an old car.
Joe
Joe
Dr. George
