pass front caliper B.jpgpass front caliper A.jpgdrivers front rotor and caliper.jpgdrivers front caliper B.jpgdrivers front caliper A.jpg
Guys,
trying to install the front brake calipers on my 69 and the driver's side pad is rubbing pretty hard without the any hydraulic fluid in the brakes yet. I can't turn the rotor by hand but I can turn the passenger side easily. I can turn the drivers side with a pry bar only. I posted these photos for your feedback. You can see the clearance for the drivers side outer pad is much less than the inner. You can also see the outer portion of the rotor on the drivers side is considerably thicker than the inner rotor surface. The rotor on the other side is basically equal from inner and outer surfaces. I think I can rectify this with a small flat washer to shim the caliper over just a little but wanted to see what your thoughts were on that.
Mike
Guys,
Mike
Figured this out when I tried to connect the brake hoses and they didn't reach. I swapped the caliper left to right and presto no problem. Thanks again guys.
