Anyone know of a source for the mushroom shaped pin that goes into the shaft of the e-brake that activates/de-activates the switch? Not the pin that holds the handle on, but the one that pushes against the brass portion of the switch. If not available, anyone know the best way to make one? As always, TIA Al
59 E-Brake Switch Pin
Re: 59 E-Brake Switch Pin
Zip has it. See http://www.zip-corvette.com/53-62-c1...-stop-pin.html
May be other vendors too.- Top
