As i mentioned in a previous post (1960 C1 fuel gauge) I am having problems with my 1960, specifically it seems to just stop while running. As we have concluded from the prior posts the fuel sender unit is most likely shot, but the car will stop while running with plenty of gas in the tank. Last week it stopped, would not start (but would turn over and start up if you put gas in the carb) but would not keep running). Gas tank was full (gas overflows when I tried to put more in). I had the car towed home (on a flat bed trailer), pushed it into the garage, cranked the engine and it started right up. And started right up the next morning. I am starting to think that although the fuel gauge may be broken, the fuel pump is good, the ignition system must be OK and the lines (at least when it is running) must be clear, there must be something that intermittently blocks the flow of fuel. I am wondering if there could be something in the tank itself that blocks the flow of gas, which then gets dislodged or moved when the car is tilted up to get onto the trailer. Does this make any sense? Is there some other possible explanation?
If this is so:
How might I check this theory?
How hard is it to clean out a fuel tank?
How hard is it to replace the fuel tank?
Do I need to take the body off to replace the tank?
Thanks for any thoughts and ideas.
Joe
If this is so:
Joe
