At some point during the 63 model GM started reinforcing the outer heater box at the hose outlet area. Does anyone know about when this started?? Thanks, Ed
63 Outer heater box Question
Re: 63 Outer heater box Question
I thought I would put this post to the top, was hoping some of you early 63 would go out to garage and take a peek at what your Corvette has for the outer heater box, Thanks, EdNew England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Ed, What exactly are these reinforcements? Do you have a photo of each type?
Rich- Top
Ed, April 20th car 133XX has no support.
I do have a spare, the ink stamp inside the box is April 1_ 63. Could be the 1st or 11th - 19th. This one does have the support. I do not know the VIN it came from. I didn't look at the A/C car.
I would make the assumption the change started sometime in late April or whenever old stock was depleted.
- Top
IMG_0539.jpgIMG_0538.jpgRich, the photo on the right shows a raised rib at the right of the hose outlet. hope this helps. the left picture is a earlier Dec. 62 the one on the right is a later Feb. 63New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Guys, thanks for the replys. I Just today cleaned up the original heater cover and found a date (Feb.7, ) on the inside of the housing, Which has a the reinforcement at heater tube outlet, So I guess my March car is considered a mid/ late production, As is Richards car.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
