I am refurbishing the gauge cluster, clock, radio and glove box for my 1967 Coupe.
I am looking for how the bezels that indicate the function of the heater, defroster, and fan controls, as well as the on, off, volume and tuning controls of the radio are illuminated with all of the other dash lights.
I know the bezels have a half moon shaped plastic shape on the back side of each one that looks like light will pass thru to light up the words on each respective bezel.
I have seen selective Corvette parts catalogs on line, with a tube shaped socket with a clip that indicates is a bulb holder(s) for this purpose.
A green membrane is to go over the rounded tip and a little window appears as a slot for light to pass through.
I do not have any indication as to where these bulb sockets go to illuminate these bezels.
Anyone seen this before and knows how there is to be light for these bezels?
There is a gray wire with a cap on it coming out of the wiring harness for the clock illumination. I suspect that this wire was cut as it is the gray wires that are used for all dash board illumination. Also, when I got the car, there was an aftermarket radio in it.
Any help to lead me to the answer(s) would be much appreciated.
Sean
'67 Coupe, '68 Convertible (small blocks)
Sean
