Water pump bolts that bolt pump to block, lock washers or not as the kit did not include lock washers. Thanks in advance.
1963 shp
Re: 1963 shp
Jerry,
Here's a 63 340HP that might answer some questions you have.
Nice 340 undergoing restoration. Ignore the blue silicone sealant.
JRDSCN4400.jpgDSCN4401.jpgDSCN4402.jpgDSCN4403.jpg- Top
Re: 1963 shp
I believe there are no washers on bolt in the passenger side lower water pump hole, as well as the driver's side upper water pump bolt, though I've seem there on some cars. The stud that attaches the pump through the lower passenger side hole also does not have a washer against the pump. The alternator brace bolt, that passes through the upper passenger side pump mounting hole, does have a lock washer under the head of the bolt. The idler nut has a flat washer and a lock washer under the nut.- Top
Re: 1963 shp
I believe there are no washers on the passenger side lower water pump hole, as well as the driver's side upper water pump bolts. The stud that attaches the pump through the lower passenger side hole also does not have a washer against the pump. The alternator brace bolt, that passes through the upper passenger side pump mounting hole, does have a lock washer. The idler nut has a flat washer and a lock washer.
Mike------
Correct.In Appreciation of John Hinckley- Top
