1968 427 435 horse fuel line - NCRS Discussion Boards
  • Valerie O.
    • November 28, 2015
    • 3
    Was wondering if anyone knows the correct rubber fuel line from the main frame steel line to the fuel pump? Are they preformed ? etc Thanks!
    Re: 1968 427 435 horse fuel line
    Valerie------
    I think that by "preformed" you're referring to a MOLDED hose. I don't know if a molded hose was originally used for 1968-69 with L-71. However, what I do know is that no such hose was ever available from GM in SERVICE. In addition, I know of no reproduction of such a hose. So, whether it was originally used, or not, it's pretty much an academic point now.
    • Valerie O.
      • November 28, 2015
      • 3
      Thanks for your help greatly appreciated
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11302
        Valerie, If you eventually replace that fuel hose, best to choose fuel-evap-pcv SAE 30R7 hose. It's rated for 50psi and is ethanol resistant. If they cut you a length from a spool just verify it before they do as the length they cut you may not have the SAE rating on it if it's a short piece.
        You can use SAE 30R9 but not necessary. SAE 30R9 is rated for today's high pressure fuel injection systems.
