66 L36 label placement - NCRS Discussion Boards
  • Bill L.
    Infrequent User
    • September 30, 2015
    • 7
    I am wondering where precisely on the radiator shroud the 3 piece (DF) inspection stickers should go as well as the Harrison foil label.
    Also, can the rear rubber fuel line from the sending unit to the hard fuel line be replaced easily without major disassembly?
  • Keith B.
    • September 15, 2014
    • 1575
    Re: 66 L36 label placement
    No Harrison foil label on a BB raditor
    • Gary J.
      • April 1, 1980
      • 1229
      Do a search about the labels, there are pictures posted. As far as the line you should be able to replace the rubber hose, if anything you may have to remove the spare tire carrier. While you are at it replace the front one too.
