My car is a 71 LS5 with automatic and no air. The AIM shows the PCV valve with a T on it with larger line going to the Rochester carb and a smaller line going from the other side to the eval canister. I have the PCV valve a 736 which has a large outlet going straight up but cannot find the correct plastic T fitting to make this work. All the ones I have found have the large ports going straight through and the smaller port making the T part. Has anyone got a picture of there original setup that I can see. Or does someone know where I can get the right pieces.
Sheldon
Sheldon
