I am trying to determine if the needle on my temperature gauge is installed incorrectly. C.S.of Md. restored the cluster and it's beautiful but the gauge will read up near 240 when the engine is hot at idle on a hot day.
I am fairly clear on how the system works and this one seems to work correct except the very hot reading. The problem is either a bad ground at the gauge, a incorrect sender (old AC unit) or the needle is not installed at the correct position.
My question is when turning the key to on position (50*cold engine) how far to the cold side should the needle move left. This needle will move to the low side of 100* (maybe around the 1 in 100). If I disconnect the sender wire from the sender it may move a tick more to the cool side, I thought I saw it move more but really not much if any.
In the summer when I let this engine idle extended it will get hot 210-220 but the gauge reads 240. I can't help but wonder if it's the needle.
