Re: 1967 won't run after 30 minutes
Just some guesses on this one....
Is it 42 degrees timing all in??? Seems like a lot really ---my 66 big block here in Georgia is set to 12 degrees BTDC and 20 degrees at the points (total of 32 all in) and it fires and runs like a top even in the summer....and it keeps on running....and no pinging at all ---- 93 octane pump gas ---
I know this is a different engine but this is just a guess ---hey it is a big block right ??? mine is a 390 by the way ----
Second:
'67's have a ton of fusible links all through the wiring system.... I know these things are supposed to blow (complete fail) given certain conditions and once they do its "lights-out" and you have to replace that link or you go nowhere------ is it possible ---again just a guess that you have one of these little beasts making contact on start up and then failing after 20-30 minutes???
Again --- I know these are supposed to be either working or "failed" in nature ---
(Just a note -- Jack Humphrey in the Colorado chapter knows a ton about these links -----he posted some good info about them quite a while back....)
Hope you get it figured out soon!!
Regards
Bill
Second:
Regards
Bill
