I've got three GM windshield channels (glass to frame gaskets) and they all have some kind of preservative on them. Kind of a waxy substance. Any suggestions on what to use to remove this prior to installing on the glass?
Windshield channel preservative
Re: Windshield channel preservative
Keith, Yes it's wax, the mold release.
It's a real pain to remove. Soapy water does nothing, even with hot water.
I use acetone on a terrycloth rag. The rag needs teeth. It's tedious but it works for me.- Top
Thanks Richard. I was hoping that you would respond. I began installing the channel without removing the wax figuring that I could clean it up afterwards but it got all over the glass and was cleaning it up with lacquer thinner. I'm thinking that lacquer thinner is too aggressive to use on the rubber itself so I'll try the acetone. By the way, I presume that it is normal for the channel to spread out initially at the wing corners? Will fitting the frames and side posts compress this area in an acceptable manner?Keith MacRae
NCRS #36692
New Mexico Chapter
1960 290HP FI
2013 427 Convertible
Shade tree mechanic and
B-52 pilot extraordinaire- Top
Do you have my installation document?
Rich- Top
Thanks again Richard. I do have your installation document and am using it as a procedural guide - it is most excellent. I see that others have used masking tape to hold the rubber channel to the glass while installing it. That's a good tip particularly when you don't have a second set of hands.Keith MacRae
NCRS #36692
New Mexico Chapter
1960 290HP FI
- Top
I was so bummed when Comcast stopped allowing personal webpage. My monthly Comcast fee goes up yearly and my services go down.
Gary- Top
Thanks E J. Good idea. I was thinking of warming it up with a heat gun anyhow before stretching it on the glass.Keith MacRae
NCRS #36692
New Mexico Chapter
1960 290HP FI
