I'm in the process of replacing the aftermarket seatbelts in my 73 convertible. I've been in contact with Charlie Santorelli about getting the correct belts. My questions are about whether or not all the correct wiring is present. After removing my seats I found the wires/connectors shown in the attached photos below. The first picture is what was under the driver's seat. I assume it connects to the retractor on an original belt. The second photo is what was present under the passenger seat. The contact bar that clips to the metal seat supports under the passenger seat is also present. Looking in the AIM I see only one connection to the retractor on the driver's side. No buckle side wire? For the passenger seat, I saw the connection to the seat contact strip, but didn't see where that extra wire on the passenger side connected. I assume it must connect to the retractor to complete a circuit if someone is in the seat?
Am I missing anything, or should I be good to go if I get the correct belts from Charlie?
I appreciate any help, Thanks
