73 Seatbelt warning light and buzzer?? - NCRS Discussion Boards
  • Jimmy P.
    • June 24, 2014
    • 1695
    Ok, I just got a set of original lap belts from Charlie Santorelli for my 73 convertible. Before I put my seats back in I wanted to see if everything worked correctly first. On the 73 the retractors have a wire connection and only on the passenger seat there is also a weight switch that connects to the seat springs. I loosely bolted the retractors to the floor and plugged everything in, including the passenger seat weight switch. I turned the key on and the dash light came on and so did the buzzer. But, when I pulled up on the belts to see if the buzzer and light stopped they did not. The belts don't need to be buckled in the 73. They light goes out and the buzzer stops if I pull up on the brake handle one click. Is there something I'm missing? I hope the switches are ok in the retractors. Or is there a relay problem? Any help or suggestions would be greatly appreciated thanks.
    Jimmy
    1973 Convertible
    L48,M20,N40
    Mille Miglia Red/Oxblood
  • Jimmy P.
    • June 24, 2014
    • 1695
    Re: 73 Seatbelt warning light and buzzer??
    I believe that I've solved the problem. The problem was with the passenger seat switch. After checking the AIM I noticed that the switch should be installed between the foam and on top of the spring. Instead of on the bottom of the spring causing it to malfunction. Should the wire in the attached photo be making contact? At least I know now that my oxblood belts are fine that I got from Charlie at Seatbelt City and my wiring is ok. Another satisfied customer.
    Jimmy
    1973 Convertible
    L48,M20,N40
    • Russ S.
      • April 30, 1982
      • 2161
      I just went thru basicly the same scenario on a customers 73. The seat weight switch can be really testy.
      • Joel A.
        • September 30, 1997
        • 205
        The switch closes when there is weight in the seat. The long strap in the middle of the switch will flex downward, pulling the "wire" into contact with the other terminal. Positioning the switch within the seat can be lots of fun(NOT). Took me quite while to get both of mine set properly years ago. On my first ever Ops check at a Regional, the car was on an incline going into the judging building for Ops. Since it was on the incline, I had to have the park brake applied....which cancels out the seatbelt warning buzzer and light...so it failed the Ops check. It wasn't until later I remembered the park brake would do that....DOH!
        Joel Adams
        1974 Coupe
        1985 Coupe
        "I know the voices aren't real...but sometimes they have some really kewl ideas...."
        • Jimmy P.
          • June 24, 2014
          • 1695
          Russ,
          Thanks for the tip, used it and everything is working fine right now
          Joel,
          I would have thought the judge would have said to "release the parking brake please, so I can check the seatbelt warning system"
          Jimmy
          1973 Convertible
          L48,M20,N40
          • Joel A.
            • 205
            Ya...you would think that I would have remembered to do so myself...first time having the car Judged...the excitement was just too much... lol
            Joel Adams
            1974 Coupe
            1985 Coupe
            • Peter G.
              • December 1, 1980
              • 406
              Originally posted by Jimmy Patitucci (60161)
              Russ,
              In a perfect world.
              Peter Gregory # 4157
              National Corvette Restorers Society Since 1980
