should I re-use my gas tank or go new? - NCRS Discussion Boards
  • Michael L.
    • December 15, 2006
    • 1387
    Guys,
    Wanted to see if there are any opinions on whether I should re-use my original gas tank or not on the 69 coupe I'm restoring. It is in good shape without any evidence of rust. I could just have it tanked and then prime and paint it, right? The other option is to just buy a new one. It's not a 427 or anything but this is a very original SB car. Everything else on this car is original and being rebuilt/restored. I'm just not sure about the quality of the repop gas tanks available. Appreciate your thoughts.
    Mike
  • Gary B.
    • February 1, 1997
    • 6979
    Re: should I re-use my gas tank or go new?
    Mike,
    Original GM tanks were not primed and painted. So primed/painted would be cause for deducts. The tanks were Ni-terne plated steel. The repro tanks from Quanta have an excellent reputation. Made in Canada, I believe. Many restored cars have Quanta tanks and they judge well.
    Gary
    • Edward B.
      • January 1, 1988
      • 537
      Why do anything?
      • Michael W.
        • April 1, 1997
        • 4290
        Yup, right down the street from where I used to work. I got ahold of the prototype '73 tank many years ago when I was restoring mine. Still looks and function like new but is discernible from an original.
        If the Op's tank is truly rust free, I'd reuse it as-is.
        • Gene M.
          • April 1, 1985
          • 4232
          Using a used tank is like using used piston rings or engine bearings.
            • 6940
            Mike, Its a lot of work to remove the tank if a leak does occur I think that a new tank is easier now than later. Its heading toward 50 years. the inside maybe okay but the outside rusts always in a lower location.
            • Bob W.
              • December 1, 1977
              • 799
              Mike Gas tank do not cost that much. And old always seem to leak when there full. Not fun.
              • Jim T.
                • March 1, 1993
                • 5351
                My 1968 tank is very good excellent condition when I shine a light into the tank to inspect it, would never even consider having it tanked and setting up a rust bucket of a tank. I had a Triumph motorcycle tank tanked once and have regretted it ever since
                • Enzo C.
                  • January 12, 2012
                  • 533
                  The quanta tanks are great and no deducts at a Regional last year... Just make sure that the fuel sending unit is correct that's all... Good luck
                  Enzo Colosimo
                  Ncrs Ontario Chapter Chairman 🇨🇦
                  ENZ-Z06/67
                    Guys,
                    Mike
                    Mike------
                    Is the car a very late 1969 with an integral pressure/vacuum valve (located on top of the tank to the left of the filler opening)? If so, understand that these valve fail and, when they do, you will get gasoline fumes in the passenger compartment. There is no way I know of to replace or repair the valve.
                    • Michael L.
                      • December 15, 2006
                      • 1387
                      Joe,
                      It is a Sept 69 car. Not sure on the valve, I will have to check the tank. I'll snap a couple of pics and send them.
                      Mike
                        Joe,
                        Mike
                        Mike-------
                        I have an original owner September, 1969. It had the valve. I'll be interested in your photos.
                        • Henry J.
                          • November 1, 1999
                          • 457
                          Joe:
                          I need an education on this valve. What does it look like? How widely was it used?
                          Thank you in advance.
                            Originally posted by Henry Jakubiec (33095)
                            Joe:
                            Henry------
                            On the outside of the tank it appears like a more-or-less flat, circular device several inches to the left of the filler opening. The center has a small "triangular" tunnel which bisects the top of the valve. From inside the tank, the valve extends down about 1-1/2" but cannot be seen.
                            This valve was used from late 1969 through 1974. It was also used on all 1963-69 SERVICE fuel tanks available from GM from about 1970 until the tanks were finally discontinued.
                            The integral pressure vacuum valve is what allowed 1970-74 Corvettes to use a sealed gas cap.
                              • 3415
                              Hi Henry,
                              Here's an example of the 'button' valve.
                              It's spring loaded with there being only about 1/16" of 'travel' from closed to open.
