Duke, et all. This is an update to my earlier post.
For review here are the specs from the ST-12.
The centrifugal advance data from the ST-12 is as follows: Centrifugal Advance (Distributor Degrees and RPM)
Start .5*-2.5* @ 400 RPM
Intermediate 9.5*-11.5* @ 1300 RPM
Maximum 13*-15* @ 1850 RPM
Under Vacuum Control it says:
Inches of Hg. to Starts 7-9"
Inches of Hg. full advance 15-16"
Max Dist. Advance 7.5*
The old VAC when tested with a vacuum pump had a start/stop of 9/17. The B26 is 6/12. My vacuum at 500 RPM idle is 15". The B26 obviously is more suited for the Two-Inch Rule.
I have now installed the B26 VAC and run the car with the following results. (This is all crank RPM)
@530 RPM - 12*
@1300 RPM - 22.5*
@1850 RPM - 28*
@3500 RPM - 34*
W/VAC @ idle (640) - 26.6*
From this data I have improved my idle advance (w/VAC) by 4.6* but I am just a little short of where I want to be at WOT. I will be getting a set of distributor weight springs tomorrow and will experiment with those to bring WOT up to 38*.
Thanks everyone for your help and input. Sully
@530 RPM - 12*
@1300 RPM - 22.5*
@1850 RPM - 28*
@3500 RPM - 34*
